Connect Prestige IAQ to Peerless 63-04
OleksiiC
Member Posts: 12
Reading Prestige IAQ and Peerless 63 manuals, but can't figure out the best way to connect the kit to boiler.
Boiler to EIM:
1. Just connect R to R, Y to W (yes, Peerless doesn't quite care about naming) and C to C
2. Put isolation relay to receptacle on the transformer assembly and then R to R, G to W and C to C
Thermostat power:
1. From EIM (will boiler transformer handle both EIM and thermostat?)
2. From another transformer
What is the proven of doing that?
Boiler to EIM:
Thermostat power:
IDK about the other items, but IIUC, the relay is to run the circulator pump if the boiler is set up for hot water heating.
- 169 Indoor-Air Quality
- 50 Industry Classes
