Beckett Aquasmart boiler control error showing water temperature 63 degrees standby
Runcoach
Member Posts: 1
in Gas Heating
I have a Peerless M1 boiler that is not firing up, even though my thermostat is set higher than the water temperature of the boiler, the Beckett 7600B control box reads water temp 63 degrees standby. Anyone have an answer for this particular problem?
Something is broke. You should call a tech who can properly troubleshoot it.
About the other thing you can do is shut it off, change the batteries in your thermostat, if they have any, turn it back on.
It's something electrical, and if its the aquastat, any company that services oil will have one on the truck.There was an error rendering this rich post.
- 15.8K Strictly Steam
