"Dripping sound" heard in wall when furnace turns on
randomuser0285
Member Posts: 2
A tenant of mine recently wrote me:
The tenant also provided a recording of the sound: https://streamable.com/j2aqca.
Is this just the sound of metal expanding? Should I be concerned? Should I have someone come out to take a look? Thanks in advance!
The issue started a couple days ago when we turned the heater on. As the heater goes through the cycle of being on to heat the place up and turning off as it gets to the right temperature, there is a dripping sound that we hear in the walls of the bedroom when it kicks on. The dripping will start when it turns on then fade after a minute or 2. There are 2 spots in the wall where we can hear it: in the wall that touches the main hallway upstairs and in the wall of the closet that touches the washer/dryer nook.
Assuming this is hot water heat; if it was a leaking drip, it would always "drip" as the system is always under just about the same pressure. Some wet spot would show up somewhere.
You could shut off the water supply and see if the pressure drops.
Turn the water supply back on unless you have a low water cut off control or monitor the system almost daily.0 -
Thanks to all for your replies. @JUGHNE, it's not hot water heat, just the electric furnace heating the house.
Is there anything that can be done to mitigate / dampen the sound, assuming it's expansion? My tenant complains that it's loud enough that it's annoying at night.0 -
I've found that as long as I know what a noise is I can generally ignore it. Maybe just explain that it is the ductwork expanding as it heats up and is nothing to worry about?
You should hear the bangs a bunch of iron pipe can make against wood framing when it swings from room temperature to 160f+.1
- 120 Geothermal
