New steam, hot water rads
STEVEusaPA
Member Posts: 6,505
Does anyone have any experience with these radiators and valves?
Thanks.
https://www.castrads.com/files/castrads-full-brochure-US100.4-online.pdf
Thanks.
No, but they look like their pretty good.
Probably need a Brinks truck to pay for them0 -
We love them.New England SteamWorks
newenglandsteamworks.com1 -
Burnham/us boiler also makes new ci radiators. Those might be more cost effective.0
The old hot water radiators can be converted to steam use by drilling and tapping the last section of the radiator on the opposite side of the steam inlet.
About 1/2 way down from the top of the radiator in the middle section where the casting is thickest drill and tap a hole 1/8" npt for the insertion of a vent valve,
There is no problem with the steam pressure as it is significantly lower than the water heating pressures.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
