New steam, hot water rads
STEVEusaPA
Does anyone have any experience with these radiators and valves?
Thanks.
https://www.castrads.com/files/castrads-full-brochure-US100.4-online.pdf
    EBEBRATT-Ed Member Posts: 18,083
    No, but they look like their pretty good.
    Probably need a Brinks truck to pay for them :)
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,528
    We love them.
    newenglandsteamworks.com
    STEVEusaPA
    mattmia2 Member Posts: 13,220
    Burnham/us boiler also makes new ci radiators. Those might be more cost effective.
  • dopey27177
    dopey27177 Member Posts: 916
    The old hot water radiators can be converted to steam use by drilling and tapping the last section of the radiator on the opposite side of the steam inlet.
    About 1/2 way down from the top of the radiator in the middle section where the casting is thickest drill and tap a hole 1/8" npt for the insertion of a vent valve,
    There is no problem with the steam pressure as it is significantly lower than the water heating pressures.
    Jake
