Small Multifamily Boiler Piping Help
Ylli
Member, Email Confirmation Posts: 3
Based on layout (see attached diagram) what would you suggest for near boiler piping changes to allow for addition of ODR control and to protect boiler from cold water return?
Also, would TRVs at each rad be the best bet to help balance heat to the apartments? Other suggestions?
My goal is to keep it simple and affordable.
Existing system info:
-100 year old building with new windows and doors.
-20year old Weil McLain CI hot water boiler 180k BTU input, single circulator on the return side. Runs well, no problems, has been inspected and heat exchanger looks clean.
-5 apartments all with cast iron rads (total of 22 rads).
-Converted gravity piping system.
-Most of the large original piping is still in place except for the near boiler piping (shown in the diagram).
-No ODR.
-Uses one interior thermostat in the apartment closest to the boiler to call for heat.
See attached for diagram.
-Each of the 5 branches go to different areas of the building and are not dedicated to any one apartment.
-Radiation to each branch is also shown.
Thank you for any suggestions.
-No ODR.
EBEBRATT - Thanks for the suggestion. I like the idea of putting TRVs in the lower apartments which are the shortest distance to the boiler. Less than half of the 22 rads will get TRVs. Do you feel an overpressure situation could happen in that case?
Any suggestion on what piping changes to make for using ODR and also protecting the boiler from cold water return?
Thanks for your help.
Bumping for anyone else's help, thank you.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
