Steam boiler
Spag74
Spag74 Member Posts: 16
edited September 2021 in Plumbing
Which is best to use when piping  a steam header connection a regular union or a cast iron flange union w/a gasket?
2” header pipe and it will be located on risers out of the boiler
    Steamhead Member Posts: 18,324
    What pipe size? Where in the header will it go?
    Consulting
    EBEBRATT-Ed Member Posts: 19,891
    Either one is fine but I would lean towards a flange union on 2 1/2" and up but neither is wrong.
    If you have a 4" union you need a pretty big wrench to tighten the nut and a big wrench to hold back on it.
    A flange union only needs wrenches for the bolts which may be an advantage in some cases
    mattmia2 Member Posts: 16,037
    Even if you have to cut the bolts on the flange at some future point it is still easier than cutting apart a fitting and all you will have to do is replace the bolts to put it back together.
  • JUGHNE
    JUGHNE Member Posts: 11,527
    A 3"union needed my 36" fully open for the nut and a 24" fully open for the fitting.
    Cheater pipes on each and 2 people with minor grunting.
    For 4" I used flanges with gaskets.
  • JUGHNE
    For 2" it seems to me that regular unions would be my choice.
    2" header with two 2" risers.....what does the install piping diagram show?
