Taco hydronic heating thermostat not working
Lowmiler
Member Posts: 4
Our home has a Taco controlled hydronic system that covers the bathing/kitchen water, the heating of the home, and a bathroom radiant floor.
Suddenly the bathroom radiant floor thermostat, a Honeywell low voltage type, has stopped working. No display. All other water heating in the house is working fine.
The Honeywell thermostat has a red and white supply wire, connected to R and W, and I get 30V AC when bridging those wires. I get the same 30V at the other end of those wires at the Taco controller. To me, that suggested a bad Honeywell thermostat. I installed a new one, and that, too, won't power up.
Kind of lost on next steps in troubleshooting. Any guidance appreciated.
Todd
Todd
What is the part# of the Taco control? SR or ZVC? Is the green LED power light on? If you jump the R-W to one of the zones, does this turn your system on? Please give us a call 401-942-8000 and ask for Tech Support. We are here from 8am-5pm EST Mon-Fri.0
Well, I guess the first set of batteries I put in were “brand new duds”, because I got home and tried another set and bingo, we’re back online.With only two wires, your thermostats needs batteries. The 30 volts that you're reading is from only one leg of the transformer and won't power the thermostat.
Thanks for the help!2 -
That actually happens often. Customer replaces batteries and it doesn’t work. I put in my batteries, it works.Lowmiler said:
Another common issue is not locking it back on the base properly, and/or bending a pin.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
