If you're needing tires for your work truck...
The 80PSI Bridgestone R265 LT245/75R16 can be had for about $140.00US each at Walmart online, with free shipping. These are the older model that's being dropped for a newer model. These are retreadable too. They are the factory tires on my 2017 Chevy Express 2500 and have worked well in Chicago and lasted about 60,000 miles. Made in USA.
STEVEusaPABillyOkcopp
  • rick in Alaska
    rick in Alaska Member Posts: 1,479
    I will have to look in to this. My Savanna is about time for new ones. Thanks for posting this.
    Rick
  • JUGHNE
    JUGHNE Member Posts: 11,419
    edited July 2021
    My 1984 one ton (retired ambulance) has those unusual 16.5 tires.
    Not much selection when shopping. One warehouse had 18 and another had 1...how does that work?
    Anyway the final bottom line bill is $195.00 each. (Firestone BTY)
    Should be the last set I buy for working.
    Could have went to 16" wheels and ended up a little less....but those classy wheel covers would not work. ;)
