Servicing Lochinvar EPC199n
Sasq40
Member Posts: 2
Had some issues with the boiler not wanting to heat up the house water today, getting the error saying low flame value or something similar, so read up the manual and figured I should take it apart to service heat exchanger. How long do you wait for it to be dry before reinstalling everything, and the top plate was so stuck on I used a plastic wedge to break the seal and it left a little indent in the seal, I'll add a picture of it, is it good to go or should it be replaced? Not sure how perfect it needs to be
https://imgur.com/a/Quu36Xy
Well I'm sure it's dry now. Would anyone have concerns reusing that seal?0
