Baseboard heater enclosure
Rod118
Member Posts: 4
in Oil Heating
Hi all
is it possible to put on a new baseboard heater enclosure without draining and cutting the pipe? I have a oil hot water baseboard system. The old baseboard enclosure was removed when the new bathroom floor went down. Thank you
Maybe... One simple option is this. https://www.slantfin.com/revital-line-series/0
It is relatively easy to install the enclosure except for the end caps. Installing the end caps will require careful cutting of the metal and fitting around the pipes.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 120 Geothermal
