Burning smell. National Us “O” Series gas boiler National US Radiator Division of Crane
patm
Member Posts: 8
Boiler number O5gW. How can I find out the year or age of this boiler or do you know? I have baseboard heat. Also, I have an odor in my house mostly in the room above where the boiler is in the basement. It does not smell like rotten eggs-more like an incinerator smell. No odor from the boiler in the basement. No odor when I put my nose right neat the baseboard but smell is in the air at face height and strongest near the baseboards. Odor is present even when thermostat is set low and heat is not on. A service tech could not smell it but said he had a bad sense of smell. He did find and remove 2 pieces of some type of boards from inside the boiler. They were like boards and were about 10 inches by 8 inches. Any information or knowledge is appreciated.
The smell might be electrical. Are there any outlets near that baseboard?
"National-US Radiator" was formed by the late 1950s merger of the National and United States Radiator companies. Crane bought National-US in the mid 1960s and sold it to Slant/Fin in the early 1970s, which still makes boilers today. So your boiler is late 1960s-early 1970s.
What did these "boards" look like? They may be refractory boards designed to keep heat from the burners from overheating the base. You really need a pro- where are you located?All Steamed Up, Inc.
Consulting1 -
I am in Livonia Michigan zip code48154. The boards were about 10 inches by 7 inches. They looked like wood boards only it was not wood. The edges looked charred and were blackened. Could you please tell me what the big part of the boiler is called. What I mean is the metal box, is this called the combustion chamber. Or fire box or what is it called?0
Smell is in the room near all the baseboards in that room and smell is in other rooms too, just stronger in one room. I put my nose against all my outlets and took many strong whiffs to smell outlets-no odor0
Dust in the baseboards? Try configuring a vacuum cleaner to blow air out of the hose, then point it into the top of the baseboard and see what comes out.All Steamed Up, Inc.
Consulting1 -
What are chamber baffles.? He took them with him. He did not know what they were. I guess he was baffled!?0
How many years is a boiler supposed to last. If I have a boiler that is from the 1950 s or 1960 s is that bad?0
My house was built in 1962. Us National was sold to Crane in 1960 and stopped production of havoc products in 1968. So I think my boiler is from the 60 s .0
Thank you Big Ed 40
You need to find someone that knows what they are doing. If he didn't understand the baffles then there are a lot of other things critical to properly cleaning and adjusting it that he also doesn't understand.
They last until they leak. That can be a very long time if the rest of the system is kept in good condition so that it doesn't leak and very little fresh makeup water with fresh oxygen and minerals gets added to the system.1 -
Any advice on how to hire someone who knows what they are doing? I hired 2 companies both well known and with good reviews and they assured me they could help. I explained the model of my boiler and the issue and they told me that they could do it, but Problem still exists. I have spent close to $700.00 .0
I live in ann arbor but I don't know anyone. i know someone that is good with sheetmetal but i don't know if i would trust them to adjust an older burner correctly.
Maybe @motoguy128 knows someone.
There is also a certification program for techs trained to do gas combustion analysis but I can't find the post about that right now. Maybe someone else can point you there. I would start by calling some that are certified. If they tell you over the phone you need to replace the boiler then they are not the right contractor. If you describe what the other tech took out, they should know exactly what you're talking about.0 -
I would Call NCI to see if they have a certified contractor in your area
https://nationalcomfortinstitute.com/pro/index.cfm0
- 50 Industry Classes
