WANTED: GB142-45 Heat Exchanger
GB142
Member Posts: 34
Just throwing it out there to see if "by chance" someone has one in Excellent or new condition. I saw there is a GB142-60 HX on here but I think it is too big.
This is the one I have. Maybe it will help.
Hi 347. I have sent you several private messages. I am interested in the HX you have. How do I get a hold of you?
I just sent a message back to you.
I am still looking for a GB 142-45 HX0
Hi all.... I am still looking for one. If anyone has a new one, I will consider that.
I need to get it sooner rather than later when it starts to get cold out.0 -
You can still purchase one off the shelf
HI Big Ed. Thanks for the heads up. I thought I might be able to find a one in good shape on the wall, but perhaps it makes more sense to get a new one.0
I see. They aren't cheap, but at least they're available.
https://www.supplyhouse.com/Buderus-7738005272-Heat-Exchanger-Kit-for-GB142-45-Boilers8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Not cheap and maybe not available? Better check ...
BTW I have spare parts available for a 145-60. Everything but the carcass / HX.
Hi @GB142 , Assuming damaged metal, have you looked into getting a good welder to fix the leak?
Yours, Larry0
- 15.8K Strictly Steam
