90 year old tub faucet leaking.
PC7060
Member Posts: 1,762
I noticed my boiler was firing to heat the indirect tank more often than normal and traced it to a very slow leak in one of the original tubs faucets in the house. I remove the first two nuts but I am now struggling to get what I think is a 1-3/8 nut off the assembly. My biggest socket is 1-1/4 so no joy there.
The first nut holds the cosmetic trim in place. The second nut (around 7/8”) I thought it would have been the one holding the shaft assembly against the valve seat.
The large nut is recessed into the tile so unable to get at it with large crescent wrench and it too stubborn to break loose with channel locks. I’m current spraying the large nut a couple times with WD40 and PB blaster to see if I can get it to break loose.
In a perfect world I’d use a really deep well 1-3/8”; any other suggestions?
A deep-well, six-point socket is the proper tool for this. You will need to remove the handle- be careful, these can break easily- and may need to grip the outside of the socket with a Vise-Grip if the stem is too tall to leave room for the ratchet handle.PC7060 said:In a perfect world I’d use a really deep well 1-3/8”; any other suggestions?
Consulting1 -
Thanks @Steamhead! I'll hunt one down and give it another shot.0
Plumber's cowbells.
The largest one is 1-7/16" and may be the one you need.The first nut holds the cosmetic trim in place.It's also the packing nut that keeps the packing tight. It stops water from coming out of the stem.
https://www.amazon.com/General-Tools-188-Shower-5-Piece/dp/B000I1QAU0/ref=sr_1_29?dchild=1&keywords=plumber's+ballcock+removal+tool&qid=1620002557&sr=8-29
Two btu per sq ft for degree difference for a slab2 -
It sounds like yours has a separate packing nut that the tube for the escutcheon screws in to, but the shower valve socket above is what you need. i think there are some odd sizes available individually that aren't in the sets.0
thanks @Alan (California Radiant) Forbes @mattmia2 - I’ve ordered the cowbells (
). I can easily get to the reverse side from access panel for the tub but no brand marking on the castings. Definitely old school and pretty basic.I’ve got another original tub with an exposed faucet and plumbing which I’m using in a new part of the house. It’s very high-quality and similar drain concept to the in wall unit. It’s only partially assembly in the picture below.
I have a couple of those that I removed years ago when I still did plumbing. Couldn't bear to scrap them as they are absolutely beautiful.
And I don't think I've even seen a tub that has a finished corner at the head. It's usually at the foot, but I guess that's what you need with that kind of drain mechanism.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I suspect that tub is meant to be freestanding other than along the back wall and both ends are enclosed with an apron.0
@Alan (California Radiant) Forbes thanks; my boss likes it a lot so basically designed new master bath around it.
1/2 right @mattmia2; fits into corner with the one exposed corner. I’m building a short wall at the end to enclose the tub which will include shelves for towels and such.The faucet spout also acts as the overflow so had to plumb in a check valve system to meet code. Restoring the valve assembly was a bit tricky but working out well.
Your tub faucet repair reminds me of the first plumbing repair I attempted at 17.
Our house tub faucet was dripping around the stem.
I got it apart down to the stage you are at.
I tried to unscrew that part you are looking at with a bad wrench.
I egg shaped/crushed that bushing. If I had left the insert in it then it may not have happened.
The insert would not go back in to stop the water flow around the shaft.
Just a heads up on what's possible.
I was in the dog house for months until the entire faucet got changed0 -
Perfect example of “good judgment comes from experience and experience comes from bad judgment”JUGHNE said:Your tub faucet repair reminds me of the first plumbing repair I attempted at 17. Our house tub faucet was dripping around the stem. I got it apart down to the stage you are at. I tried to unscrew that part you are looking at with a bad wrench. I egg shaped/crushed that bushing. If I had left the insert in it then it may not have happened. The insert would not go back in to stop the water flow around the shaft. Just a heads up on what's possible. I was in the dog house for months until the entire faucet got changed
2 -
I very much enjoy repairing/rebuilding this type of valve. It was made in the days when things could be repaired.
When I do tackle one of these jobs I always say, "How far do I go until I've gone too far?"
It is always A tough call when starting one of these. Because of its age, the fear of it breaking is always on your mind. I try to have any and all repair parts in hand before I begin.
And then I keep in the back of my mind what I might use to replace the whole darn thing.
2 -
@Alan (California Radiant) Forbes -The cowbell (second largest size) fit the large nut and was able to break it loose with the help of a large crescent wrench.
I replaced the washers on both the cold and hot valves. Determined the slight leak on hot size was caused by casting defect in valve body which prevented screw from being able to tighten fully. I replaced it with stainless screw that is 3/32” longer which allowed it to fully engage the rubber washer.During the rebuilt process I found the manufactures was Speakman. The quality of the old units are certainly much better than the new Speakman products.All is good now with minor issue that the Hot valve is not aligned horizontally when closed. May have been like this when I started.I noticed the mounting hole in the two handle are 180 out from the other; no way I can see to adjust since the metal is fused into the porcelain.How did the skilled dead men who installed this get the labels to align properly?
2 -
It isn't a multi spline broach that allows you to install it in several orientations? It is going to go out of alignment as the washer wears anyhow. The stem may be several intertwined threads that threads in to the cartridge in several orientations. That is how they make stems that open and close with less of a rotation.
You might want to get a new setscrew for that while it still comes apart or maybe get a stainless allen setscrew. I'd dope everything threaded up with ptfe pipe dope so it doesn't seize together the next time someone needs to take it apart.
It being speakman i bet most of those parts are still available.0 -
@mattmia2 - The handle is a square mount with one threaded section through two side so limited to two positions. Could drill and tap the other face which would solve the problem but not my first choice.I think you are correct about the rotation of the intertwining threads; I pulled apart and could have easily rotated off by 90. I’ll pull the hot side apart again and see if I can realign the stem.1
So it is like a doorknob from before they threaded the spindle?0
@mattmia2 - The valve has a single thread with a “square broach” (example below) so handle alignment is limited to two positions .
I noticed the Hot is oriented vertically in the original photo I posted so this is nothing new. Valves shut off easily with no leaks so best to declare success and move on!0 -
the thread on the stem itself, inside the bonnet? Is that a whole new cartridge?0
Yes, you are correct. The picture is a example of a similar Speakman part with square broach. I located a rebuild kit on eBay with splined spindles and new handles for a Speakman tub control and shower diverter which may fit. No use for shower diverter and the boss likes the old handle and thinks I should “leave it alone”.
- 15.8K Strictly Steam
