Brockmann thermostatic valve actuator replacement?
Chuck_17
Member Posts: 148
See attached. Is there a replacement actuator available?
(The owner feels it is the actuator, not the valve.)
How about that escutcheon piece?
I assume that actuator can be removed with water in the system?
Was Braukmann bought by Honeywell?
[url=https://postimages.org/][img]https://i.postimg.cc/gJwd3VvS/Braukmann-1.jpg[/img][/url]
[url=https://postimages.org/][img]https://i.postimg.cc/VNZmSGb0/Braukmann-2.jpg[/img][/url]
It does not look like the photos are visible. Here is another try:
Sorry.
Help?0 -
Braukmann is Honeywell as far as I know0
Yes. That knurled ring will release the head leaving the actual valve behind. Keep in mind that it is sometimes the valve insert that fails.
Closing "travel distance" and thread matching is the tough problem between manufacturers. Braukmann and Honeywell seemed to use M30X1.5mm threads. This might be a match and at $33 bucks is a cheap thing to try... https://www.supplyhouse.com/Honeywell-Home-T2040NA-Thera-4-Universal-Thermostat-Radiator-Actuator-w-Internal-Sensor-Danfoss-RA-Connection-Adapter
- 167 Indoor-Air Quality
