Telestat
Member Posts: 4,567
Does anyone know of a replacement for this actuator? It's threaded on to the manifold.
Thanks in advance.
Thanks in advance.
Do you know what brand manifold? Threads are usually all the same from brand to brand, but the pin stroke doesn't always match.
It looks like a brand that Watts radiant bused once?Bob "hot rod" Rohr
Good point. I'm going by there later today and will check the manufacturer.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Old 2017 thread but I have identical Telestat to your picture. Valve body is Heimeier/MNG/Oventrop with M30X1.5mm threads. I found a cross-reference to Braukmann MV100S8011... problem, that is obsolete too. My 2nd floor is a single pump feeding 4 bedrooms each with a Telestat. How did you solve your problem. Appreciate the help...0
I am looking to replace 45 of those same actuators on Watts manifolds.....0
@Alan (California Radiant) Forbes you may want to get yours first before @heaterdude buys them all up LOL._HeaterDude_ said:I am looking to replace 45 of those same actuators on Watts manifolds.....
Y'know, I remember replacing those actuators, but I forgot which ones I used.
I would call Watts as they would (should) know.
And it would be great if you let us know what you figure out.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I guess it might depend on the vintage of the manifold. Geptuft was one of the stainless manifold manufacturers that Watts used. This one is probably late 90's into the 2000s. Maybe they still use this brand?
The Caleffi TwisTop seems to work fine. It opens and closes completely. It's the pin stroke that is important so the valve moves the correct amount.
The uniquely designed Caleffi pex fittings seal also. This pex adapter has a tapered flow path for excellent flow.Bob "hot rod" Rohr
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
