WANTED: GB142-45 Heat Exchanger
GB142
GB142 Member Posts: 34
Just throwing it out there to see if "by chance" someone has one in Excellent or new condition. I saw there is a GB142-60 HX on here but I think it is too big.
  • 347
    347 Member Posts: 149
    This is the one I have. Maybe it will help.
  • GB142
    Hi 347. I have sent you several private messages. I am interested in the HX you have. How do I get a hold of you?
  • 347
    I just sent a message back to you.
  • GB142
    I am still looking for a GB 142-45 HX
  • GB142
    Hi all.... I am still looking for one. If anyone has a new one, I will consider that.
    I need to get it sooner rather than later when it starts to get cold out.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,360
    You can still purchase one off the shelf
  • GB142
    HI Big Ed. Thanks for the heads up. I thought I might be able to find a one in good shape on the wall, but perhaps it makes more sense to get a new one.
  • I see. They aren't cheap, but at least they're available.
    https://www.supplyhouse.com/Buderus-7738005272-Heat-Exchanger-Kit-for-GB142-45-Boilers
  • woobagooba
    woobagooba Member Posts: 186
    Not cheap and maybe not available? Better check ...
    BTW I have spare parts available for a 145-60. Everything but the carcass / HX.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,005
    Hi @GB142 , Assuming damaged metal, have you looked into getting a good welder to fix the leak?
    Yours, Larry
