Which filter
leaking
Member Posts: 152
I just had two AO smith 540 199,000 btu tankless installed in an apartment building. There is a anti scale filter AO sells for about 500$ each, I need two. Is there anything cheaper ? AO sells the smaller filter I can get it for 125$. I think I can use 4 of them but I am looking for other ideas to do this right.
I forgot to say it’s Chicago water, 7.6-8.6 hardness0
Hi, Another reason to go with a non-salt softener approach is that salt makes the water more conductive, eating up the anodes in the tanks. I've seen them completely used up in six months with salt softened water. You should leave 3-6 grains of hardness in the water to protect any copper piping as well.
Yours, Larry0 -
Look at the 3M AP430SS. Relatively inexpensive and easy cartridge changeouts.0
- 116 Geothermal
- 169 Indoor-Air Quality
