Damper motor
k0bossy
Member Posts: 1
Please help me find a replacement motor for Effikal rvgp-pc-4bkf-cp.
It is buzzing trying to open and close. I have to manual move the shaft till it stops buzzing for it to move to opposite position. I currently have it on manual open.
Are you sure it's the motor and not the linkage or damper?
I would replace the who damper assembly.0 -
Field Controls bought out Effikal. The replacement motor assembly is Field part# GVD-RMA. This includes the actual motor, switches and gear drive, and bolts onto the damper with the two mounting screws. The cable plugs into the motor assembly.
This might be a good time for a pro to give your boiler a once-over.All Steamed Up, Inc.
Consulting1 -
Hey k0bossy, Did you find a replacement? I may be able to help.
Dan
- 50 Industry Classes
