Damper motor
Please help me find a replacement motor for Effikal rvgp-pc-4bkf-cp.
It is buzzing trying to open and close. I have to manual move the shaft till it stops buzzing for it to move to opposite position. I currently have it on manual open.
    HVACNUT Member Posts: 7,424
    Are you sure it's the motor and not the linkage or damper?
    I would replace the who damper assembly.
    Steamhead Member Posts: 18,456
    edited February 2021
    Field Controls bought out Effikal. The replacement motor assembly is Field part# GVD-RMA. This includes the actual motor, switches and gear drive, and bolts onto the damper with the two mounting screws. The cable plugs into the motor assembly.
    This might be a good time for a pro to give your boiler a once-over.
    Consulting
    Hap_Hazzard
  • DPLivingston
    DPLivingston Member Posts: 1
    edited May 2021
    Hey k0bossy, Did you find a replacement? I may be able to help.
    Dan
