O2 barrier pex or regular PEX & bronze pump for closed exchanger loop off DWH?
Jells
Member Posts: 618
I'm heating a small apartment from it's water heater, done this before as open system circulating potable water, but I'm now trying to do it safer and use an exchanger with 2 pumps. Should I just use a bronze pump on the heater loop like I always have, or a regular cast pump and barrier PEX? The pump price difference seems like it might be worth it since I read the barrier PEX is harder to work with than standard Pex-A. There's no other O2 sensitive components in the closed loop system, just air bleeds, checks, and expansion tank.
Your creating a separate closed loop with it's own make up water and expansion tank. I don't see any need for a bronze pump or anything special0
But then if I don't use barrier PEX aren't I putting a cast pump at corrosion risk? Or is it just too little footage of PEX, I'm feeding kickspace heaters not radiant loops.EBEBRATT-Ed said:Your creating a separate closed loop with it's own make up water and expansion tank. I don't see any need for a bronze pump or anything special
Believe @EBEBRATT-Ed meant for you to use O2 barrier rated PEX and standard closed system pump.0
Use barrier Pex A and a cast pump which is much cheaper than a bronze pump, if a closed sys. The length of the circuit as well as the size of the tube has a lot to do with pump sizing . One usually fall within a range of 3/8" to 3/4" tubing. Pay attention to ED's comment about makeup water and expansion tank. A Fill-trol would be my choice.
If you use a flat plate heat exchanger and you use potable water, you will need two pumps. a bronze one and a cast one. If you use potable water for heating it must be done right to prevent legionnaire contamination. See: radiantec's solution.
https://www.radiantec.com/about-radiant-heating/our-heating-systems/0 -
So Radiantec's potable water heating system is safe because the DHW source pulls exclusively from the Water heater where it has been heated to safe temperatures? Seems like you would need a mixing valve at the point where cold water enters the system to reduce the floor heating temp based on ODR. Not sure why you would supply outside waterline from a "pre-heated" source as shown.HomerJSmith said:If you use potable water for heating it must be done right to prevent legionnaire contamination. See: radiantec's solution.
Youngplumber said:@PC7060 it's "preheated by mixing with the return water from the loop.
@HomerJSmith what happens with this sytem after two showers? Or one long one? Do you just temporarily lose some heating capacity?
@h@HomerJSmith thanks but I know all of that about how to construct the system. I've just found that making a question.too long and complicated leads to fewer answers here, and thought that 'safer'and 'exchanger' would show that I know this stuff.1 -
I'm heating this time with kickspace heaters, others have traditional baseboard, so I want to run as hot as I can, close to 140. I put a mixing valve on the DHW out. I posted here because of the similarities to radiant systems.PC7060 said:@Jells - so do you use a mixing valve or does the heating loop get the full 100-130F temperature water from tank if there is no ongoing call for DHW?
All DHW heaters should be 140 with a mixer to eliminate the Legionella risk. I've tried discussing this with local plumbers and suppliers, all of them poo poo the whole thing and still recommend circulating potable water. TBH, I haven't had any issues in the many years I've had them, but why not do better if you can? Another $500 in gear and some labor doesn't make much difference in the long run.1
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
