Thank you
keith123
Member Posts: 105
I’ve been contacted
Can you provide a little more context? And some pictures?
There’s a separator required as well0
I tried contacting Igor anyway I could with zero luck. Worse case I’ll just have to figure out what specific equipment was used. Of course being told what pump and separator was used is much easier.Oak vacuum pumps does make them, but the manufacturer explained to me, they feel he used another brand.0
I just sent Igor this thread.keith123 said:Hi. I’m just learning about this genius design by a fellow named Igor. Does anyone know what manufacturer pump model is used for this? I’m excited to do this. I have a job coming up that’s perfect for it.
Where are you located?
Is this a single pipe or a 2 pipe system?1 -
Single pipe. North Jersey. Thank you !!0
