Insulation on Water Baseboard
Tha_goat
Member Posts: 1
Hi all,
We have a section of baseboard that runs behind the bed. As expected, when it heats, it warms the whole bed, which isn’t ideal.
Moving it really isn’t an option either.
Thinking about options, I was wondering if some sort of insulation or reflectant would be safe and reflect the heat back in. Any of you have any thoughts or suggestions for this?
Thanks is advance
Thanks is advance
Cover the top of that section of element in aluminum foil. Hope there is enough element in the rest of the room to still adequately heat the room.0
- 50 Industry Classes
