Radiant heating on the Mars probe
nicholas bonham-carter
Member Posts: 8,580
The second issue was a transient event involving temperature on the spacecraft. The mission uses a liquid freon loop to bring heat from the center of the spacecraft to radiators on the cruise stage (the part that helps fly the rover to Mars), which have a view to space. We monitor the difference in temperature between the warm inlet to the radiators and the cooler outlet from the radiators. As the spacecraft entered into Earth’s shadow, the Sun was temporary blocked by Earth, and the outlet temperature dropped. This caused the difference between the warm inlet and cooler outlet to increase. This transient differential tripped an alarm and caused the spacecraft to transition into the standby mode .
Full story here, (just landed safely):
https://www.space.com/news/live/mars-perseverance-rover-updates
The old delta t trip thingieBob "hot rod" Rohr
Living the hydronic dream0
- 50 Industry Classes
