Noisy pump, maintenance, add filter?, what's in the water?
MrScott
Member Posts: 25
Hi! I'm a homeowner with a hydronic system that I don't think was maintained for several years. Wondering what needs to be on the maintenance schedule?
- Would you put in a filter? Water is black.
- Would you add corrosion inhibitors? I don't know what is in the system now. Soft water here.
Will have a contractor clean and maintain the boiler this week.
I want to understand the system better; fix what I can, avoid the more expensive uninformed mistakes (and not try to fix what I can't), accurately report symptoms, and understand what the HVAC contractor is saying for the rest. I have an (electronics) engineering background.
What should I be doing for maintenance?
Some of the equipment:
Buderus GB 142-24 propane-fired boiler.
Buderus ST300 storage tank.
Grundfos circulation pumps (UPS15-58 FC/LC at boiler circulation loop, UP26-64 F circulates tank to boiler).
Thank you!
Scott
Thank you!
Scott
* Replacing the sacrificial anode in the storage tank. I'll be surprised if there's anything left of the previous one...0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
