Heat Timer Synchro motors
I'm hoping someone can help point me in the right direction.
Im looking for new synchro motors (with bronze gear) for Heat Timer controls for Steam
The stampings on the motor are: 610 24V 60hz 3W 1RPH A 212RC-1WR-6 0108
The bronze gear has 14 teeth.
I tried Hansen Motors but they no longer make or stock these motors.
Tried eBay but either they aren't 24v or the RPH is off, or the wattage is wrong.
Heat Timer will not sell the motors seperately. They want to charge for a service call to diagnose the problem, then charge for the repair and re-installation.
Does anyone have a lead where I can get these?
Ideally, I'd be buying about 5-6 of them.
TIA
    EBEBRATT-Ed Member Posts: 18,815
    Try Interstate Controls 1-617-782-9000
    Brighton, MA
    They used to do a lot of Heat Timer stuff. Maybe they can help you out
    If you need to replace a Heat Timer, Tekmar has a control that is much better and less $$$. I think it is a number 279 but you can find it on there web site
  • enosez
    enosez Member Posts: 4
    Gave them a call and they cant help.
    Trying ebay I think I found a few that might work,
    Hopefully they are good when they arrive.
    If anyone else has a contact they could share, I'd appreciate it.
    Thank you EBEBRATT-Ed
