Looking for Weil & Mclain Recessed radiators
Have some of these and need more anyone have any sources? I can't find anywhere.
    EBEBRATT-Ed Member Posts: 20,144
    There are recessed rads available. Wether they would match what you have is a different matter
    Steamhead Member Posts: 18,464
    I think we might have a couple- not the exact model but close enough. Where are you located?
    Consulting
    kcopp
  • Nick7887
    Nick7887 Member Posts: 5
    New Hampshire, please send pictures to rowing0307@outlook.com
  • 253NoMain
    253NoMain Member Posts: 1
    I have a house full of the exact same, I'm considering converting to hot water.
    Are these tube type? or column?
    They're beautifully recessed and its obvious it was state of the art in 38' and really can't imagine replacing.
    just not very efficient
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    Check out Burnham SunRad radiators ..
    mattmia2 Member Posts: 16,665
    the only thing that isn't efficient about them is that the wall doesn't usually get insulated behind it.
    Why are you considering converting to hot-water? Is the present system steam, is there a problem with it?
    Consulting
    kcopp
