Equalizing line
Bruce_29
Member Posts: 9
Ref a vacuum steam heating system with an equalizing line between the condensate return system and the boiler steam header. Mechanical vacuum pump to generate the vacuum.
Why is the check valve that is installed in the equalizing line in a water loop seal (trapped) below the horizontal line elevation by about 6" of the pipe itself?
I have heard to keep a better seal between the seat and check valve disk, it will remain cleaner then if it was in the steam line as contaminants might be deposited on it, the 6" gives you a differential for proper operation, to prevent the disk from chattering, etc.
The purpose of the check valve in the equalizer line being dropped is to trap some water so the valve seat becomes water sealed.
Not often seen, but equally effective is a thermostatic radiator trap at the end of the uncovered cooling line where it drops down to the return line.
See attached illustrations.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
@Bruce_29, yes, most of the literature I have came from Nash. I have most of Nash's engineering and installation drawings. Most are post 1950, but some are earlier.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
- 15.8K Strictly Steam
