Maxxon 4 way mixing valve
BillyO
BillyO Member Posts: 277
Can anyone tell me if parts are still available for a 1" maxxon 4 way valve before I replace it, Thanks
    EBEBRATT-Ed Member Posts: 19,586
    Google isn't bringing anything up. Do you have any more information? Do you mean "Maxon" as in the company that makes gas valves etc.
  • Dave H_2
    Dave H_2 Member Posts: 621
    Maxxon is a company that deals with poured underlayment systems and in the past if I remember correctly, they would also have dealers install the RFH system.
    Looking at their website today doesn't show any RFH products other then the gypsum flooring system.
    You probably will need to replace the valve depending upon what's going on. Maybe its a controller issue? Programming, sensor issue?
    Dave H.
    Dave Holdorf
    Taco, Inc
  • BillyO
    thanks guys, Maxxon 4 way valve with leak from stem. pretty sure Maxxon was IN FLOOR or visa versa. swapped it out already
    Dave H_2
