Honeywell L7224U low limit bypass
jpotter04210
Member Posts: 1
Does anyone know how to bypass the low limit on a Honeywell L7224U?
I just had to replace the control assembly on my boiler as it was faulty. The old assembly was analog and so i installed a timer to bypass the low limit switch during the day and night when no hot water usage was anticipated. It has worked very well for 15 years or so. I can't see how to bypass it on the new digital model.
I think you're out of luck. But maybe, you can add another temperature sensor and wire your timer to ZR. If I had a few moments I could put my brain to it.
But I bet @EdTheHeaterMan could figure it out, with diagramsThere was an error rendering this rich post.
@jpotter04210 Press and Hold the 3 buttons < > I Up, Down, and Information This will put you into program or setup mode.
Once you see the display change to HL then you are in the program mode
Now press the I button to toggle thru the program menu 2 times. the display will say LL that stands for low limit
now press the down arrow to lower the temperature to the lowest setting. On OEM controls that may be 120°
on the L7224U the lowest setting is OFF
That should do it but you cant connect a timer to it to bring it back on.
If you need to maintain temperature for DHW on a timer you will need to get the old analog control and set it up with the timer like you did on the original control The contacts in the digital control for low limit don't have wires that you can disconnect to insert a set of timer contacts.Edward Young Retired
There may be a way to do the timer using the ZR and the controls programming BUt you will need a second aquastat to measure the boiler temperature at the Low Limit Setting. You will need an L4006A aquastat and a place to install it in the boiler using a Well Adaptor. Is there an extra tapping in the boiler near the top where you can do that?
@jpotter04210 If yes then I can go over the details if you are interestedEdward Young Retired
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
