Descaler Recommendations
Hi,
I need to descale my Navien NCB-240 on the heating and hot water sides.
I've been looking around for a good descale fluid.
There is the Hercules Haymaker Tankless Water Heater Descaler and Qwik Descaler.
Would either of those be good?
Any other recommendations?
Thanks
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,096
    Hi @JoeCap , The only other descaler I commonly hear about is white vinegar. I trust you are using a pump and bucket to pump the fluid from and back to?
    Yours, Larry
  • kcopp
    kcopp Member Posts: 4,678
    I have used vinegar and Haymaker.... Haymaker is a great product. Uses Citric acid to eat through the calcium. That would be my choice.
