Leaking radiator
ImYoungxD
ImYoungxD Member Posts: 130
edited December 2020 in Strictly Steam
Anyone know what hex tool size I need to get this fixed or can I do something else? I checked Home depot, harbor freight and they don't have the size I need.
https://photos.app.goo.gl/XiGxuLnbnbFM48Z8A
  • JUGHNE
    JUGHNE Member Posts: 11,546
    Have you tried the hex head of a bolt.....maybe metric.
    If you find a match then 2 nuts jammed together will give you wrenching flats. Maybe a high grade bolt, shorter is better for wrenching close to the plug.
    Is it brass or steel?
    Spray might be needed.
  • ImYoungxD
    That's a good idea. Pretty sure it's steel.
    Thanks
