Pennco Iron Cast Boiler Water Leakage
sydney
Member, Email Confirmation Posts: 3
Hi,
This Pennco boiler was installed three years ago but just had a minor repair last year. It was having trouble with hot water a few weeks ago and now, it seems to stopped working. There's a really bad water leakage, which I am not familiar with the terms of the valve. Can someone let me know what I can do to fix it or what I should tell the plumber to do? I wasn't really expecting it to breakdown. Send help, please and thanks.
And I feel like it's letting out fumes before it happened.0
@sydney
Looks like you have a bunch of small problems. A few leaks and the boiler relief valve is dumping water. The relief valve problem could be a bad relief valve or a bad water pressure reducing valve or an expansion tank issue.
Looks like you have a few minor leaks to be fixed on the piping as well.
If the boiler is not operating I can't have an opinion on that without further information.
We cannot talk about any pricing or repair costs. That is against forum rules.
I would suggest calling your service technician.
If you need one , post your location and check "find a contractor" on this site0 -
@EBEBRATT-Ed Thank you for your help!0
