Gf200
jimachangaz
Member Posts: 3
in Gas Heating
I have a GF 200 that will not start. It is getting gas/ purged the lines. I checked the exhaust which is clear. Any help would be appreciated. Here is a video.
https://youtu.be/yugmSuXYhKE
https://youtu.be/yugmSuXYhKE 0
Pull and clean the igniter maybe. Not real familiar with that unit.0
I pulled it its getting spark you can see it0
Maybe put it in second and roll it down a hill?0
When was the heat exchanger/compartment last cleaned?
Is there a drain hose on the heat exchanger.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
