Staple up PEX turning black
styxplo
Member Posts: 55
I'm noticing that my PEX seems to be turning black. I installed this about 9 months ago. It was commissioned at the end of the season last year. I flushed it with new system cleaner then filled with mostly distilled water a small amount of spring water to get the hardness within the range of the boiler specs. the system has embeded, staple up, and 3 radiators. Is this something I should be concerned with? Thanks
The pex is turning black. How about the water when you flushed it?
O2 pex?There was an error rendering this rich post.
Yikes, working on commissioning my own system soon. What brand is the pex?0
Sounds like it may not be oxygen barrier tubing. What brand did you use?0
That is not uncommon. It is tough to keep hydronic fluid crystal clear.
Was the system cleaned and flushed of pipe dope, solder flux, cutting oils, etc? That can contribute to coloring of the fluid.
Even so the ferrous metals will cause the fluid to color.
i like to add hydronic conditioners, after the clean and flush. So the color you see is doing good things in the system
Living the hydronic dream1 -
That will tend to do that w/ a cast iron block boiler and ferrous piping.0
Maybe use some 8 way boiler treatment and install a Dirtmag.0
