Add a loop
Snowmelt
Member Posts: 1,416
2 questions ,
What aqua stat are you using for these set ups and what pumps are you using g ?
What set ups?0
My fault, the add a loop on a steam boiler0
Open on rise aquastat.
3 speed circulator.0 -
3 speed bronze or stainless circulator0
I thought we want the biggest velute ( passage way so nothing gets clogged up0
Most of the time I only see basic 007 pumps being used in this application.
I've never seen a bronze or SS circulator used on anything but domestic water.
Maybe @Paul Pollets can explain why thats better.0 -
I've used cast iron circs, but get twice the life out of a stainless or bronze pump.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
