Leaking
louanne85
louanne85 Member Posts: 1
edited November 2020 in THE MAIN WALL
When using my sink in the upstairs bathroom I can hear dripping. Then when I go downstairs there’s water dripping from the ceiling and a large amount of water on the floor coming from under the cupboards under the kitchen sink. No idea what to do any help would be welcome
  • Grallert
    Grallert Member Posts: 1,037
    Check to see if you can see the leak under the sink in the upstairs bathroom. If not you'll have to determine where the leak is. You might have to open the ceiling and work from there. You'll have explore unfortunately.
