I think...
Steve Minnich
Member Posts: 2,868
Me too. I can draw a little on Visio but will never be able to do what your doing0
If I can do it, you can do it. I struggled with it at first because I’m relatively new to it. But once you do get it and the light goes on, you own it.Steve Minnich0
One thing about Visio that always annoyed me was the inability to insert tables or other formatted text. Then I learned you can build whatever you want in Word. When done that can be inserted into the drawing as an object. After that the original is no longer needed as the object can be changed from within Visio by automatically launching Word. Now I'm happy.0
@RayWohlfarth This is Siggy’s HydroSketch web based software. All of the symbols I used are available in the software, although you can import others.Steve Minnich0
