Biasi B10 series
masonjakes
Member Posts: 1
in Oil Heating
I have intermittent error lockout with my Biasi boiler. I have replaced the nozzle and filter- checked cleanliness of the boiler and water press is good. I’ve read most burners for this model are Riello but this is a Becket genisys. Any suggestions?
Besides call a professional?
A competent tech will have a contractor tool to read the run/fault history on the primary control. Then they will use their knowledge, skills, meter and tools to troubleshoot the problem.
Then they will perform a combustion test (draft, smoke, analyzer) to make sure your burner is set up properly and running safely.There was an error rendering this rich post.
2
- 120 Geothermal
