Embassy ONEX
13»
  • Tom_133
    Tom_133 Member Posts: 970
    last one i did, if my memory serves me, the brackets were screwed in, so I unscrewed the brackets and removed the tank. Or was that a Baxi?
    Tom
    Montpelier Vt
  • ekc
    ekc Member Posts: 7
    The top bracket looks like this with round riv
  • ekc
    ekc Member Posts: 7
    Top of tank with bracket. Looks like I have to pry the tank out. Hope I don't break the bracket.
  • Danny Scully
    Danny Scully Member Posts: 1,465
    From my experience, not really @ekc. I usually re-pressurize them in place (if the bladder isn’t broken) and add an external one if necessary.
  • kcopp
    kcopp Member Posts: 4,673
    That is a Zilmet tank.
    Pretty expensive to replace.
    I agree w/ @Danny Scully to try and re-pressurize it w/ a compressor.
    50/50 shot at it working.
    If you need to pull it disconnect the nut at the bottom . push it up and the bottom slides out. I have done a few.... make sure to have a bucket underneath.
  • ekc
    ekc Member Posts: 7
    Thanks for your advice.  I was able to empty tank and repressurize without having to remove tank.
