HYTECH Boiler - 1983 Wall Hung
davekay2
Member Posts: 1
HYTECH Boiler - 1983 Wall Hung that are nat gas can they be turned into lp gas they are new never been hung thank you for your time Dave
Never saw one but if you could find a manual it would probably tell you, Most boilers can burn natural or LP but may require an orafice change.....maybe other parts0
I used to service a lot of those units. The last supplier I knew of was Gourley company in Waltham Mass. They may have somebody there who knows.0
We worked on quite a few. They were funny little creatures, had many last 30 years plus. They were some of the earliest on demands. Used water diaphragm valve to open the gas train.0
They had/ have a huge grundfos 26-64 on it.
The pressure drop through the HX must have been huge.
I wonder why they didnt pipe them pri/ secondary?0
