HYTECH Boiler - 1983 Wall Hung
davekay2
davekay2 Member Posts: 1
edited October 2020 in THE MAIN WALL
HYTECH Boiler - 1983 Wall Hung that are nat gas can they be turned into lp gas they are new never been hung thank you for your time Dave
    EBEBRATT-Ed Member Posts: 18,209
    Never saw one but if you could find a manual it would probably tell you, Most boilers can burn natural or LP but may require an orafice change.....maybe other parts
  • kcopp
    kcopp Member Posts: 4,577
    Very odd to have that boiler(s) still new. By chance did you find them in NH?
    davekay2
  • I used to service a lot of those units. The last supplier I knew of was Gourley company in Waltham Mass. They may have somebody there who knows.
  • tim smith
    tim smith Member Posts: 2,875
    We worked on quite a few. They were funny little creatures, had many last 30 years plus. They were some of the earliest on demands. Used water diaphragm valve to open the gas train.
  • kcopp
    They had/ have a huge grundfos 26-64 on it.
    The pressure drop through the HX must have been huge.
    I wonder why they didnt pipe them pri/ secondary?
