Ways to break down steam boiler
Dairon421
Member Posts: 81
in Gas Heating
Hey guys, are there other ways to break apart boilers without using a hammer and chisel
Some type of wedge and a hammer. If it has draw rods cut them off and put new draw rods on with the nuts and washers on the inside and us them to force the sections apart if you can0
NO.0
You can also cut the sections with an angle grinder with a cutting disk. And you don't have to cut the section completely. Cut what you can and rap it with a hammer0
