propane regulation ?
moneypitfeeder
Member Posts: 252
I have a small propane system set-up in a remote off-grid cabin where the regulator and outside piping hasn't been changed since before we brought the property. The propane fuels the 1950s-60s gas 4-burner and oven range, the refrigerator, and 2 propane lights. The original tank was a 60lb tank, and we now cycle between a 30lb tank and a 20lb back-up to make it easier to lift and take in to town to refill. Inside the cabin the exterior hose connects to a 1/2" black iron manifold with separate take-offs to the range and the fridge (standard yellow sleeved gas lines with shutoffs and leak-detector automatic shutoff valves) and an additional shutoff to a 1/4" flex copper line to the 2 lights. Outside the tank connects to a regulator (Marshall model 260, 2-stage lp reg, listed 605H, outdoor use) and then to a standard 1/4" POL rubber hose. Question is, is the regulator and POL hose the correctly rated regulator and connection to the cabin? We need to replace them due to age and rubber gasket/hose decay, they are both due, but we don't want to replace them for "like" items if they weren't correct from the get-go. Everything "works" but the flame on the range has always been finicky (might just be the range) the burners only seem to work on full high or full low, mid-ranges the gas flame flickers and dies out. I'm really wondering if the 1/4" outside line isn't able to fully deliver enough gas for the 1/2" inside appliance line. I'd appreciate it if anyone with propane regulation experience can help steer me in the right direction.
Here are some photos of the set-up and thank you to the moderators for moving this to the correct location.
And a few more photos
Is the small hose with the POL connected between the tank and regulator? That should be large enough, being that short, to feed the regulator as that is the high pressure out of the tank.
Then does the regulator connect to the 1/2" cabin piping?0 -
Right now the setup was the tank, to the hose, to the regulator, to the 1/2" black iron pipe the extends from the inside to the outside. Is that backwards? And do you think the regulator is sufficient? Thanks!
Your connected load is likely around 100,000-125,000 btu/hr total. That means even the smallest twin stage regualtor is more than sufficient.
You can use an RV type auto changeover and connect both tanks. That's what I'd do.
https://www.homedepot.com/p/Flame-King-2-Stage-Auto-Changeover-Propane-Gas-RV-Regulator-Kit-with-Two-12-in-Pigtails-KT12ACR6/309005434
Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Thank you very much for your advice!
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
