How To Flush Out Debris from Governale-type Rad Before Pressure Test
D107
Member Posts: 1,944
Got my 8 section OCS with its 1.25" input/output, and have the necessary bushings etc to connect one end to pressure gauge and the other to garden hose. Before I pressure test, I wanted to flush out some rattling debris inside the rad.
Plumbing supplier said don't use teflon on the bushings into the rad since somehow that could allow too much pressure and burst the rad--said to use pipe dope. Without him saying that I probably would have used telfon since I'm looking for a very temporary connection. Anyway he also said no need to test to 30 psi, since heating usually only goes to around 15. I know that, but when they do a boiler pressure test, or somethiing malfunctions, won't pressure reach 30? Or is he hoping the rad isn't crap and bursts and then has to replace it since I bought it there?
Anyway I thought I'd first fill up the rad to about 10psi then remove the pressure gauge end bushing and then keep the hose on and flush it out. Make sense?
