Lochinvar Noble cleaning
Le John
Member Posts: 250
in Gas Heating
Hope all of you are well. I want to clean the water side of my Noble NKC and Lochinvar recommends using a 5% vinegar Solution. Isn’t the vinegar harmful to the pumps. Is there any other solution you would recommend?
The domestic water side of the combi? If so use the acid they sell for flushing tankless water heaters.
If you have isolation flush valves the cleaner only goes through the HX.
These kits are handy if you plan on deliming yearly.Bob "hot rod" Rohr
Living the hydronic dream0
