Logamatic 2107
Fuseblower2
Member Posts: 3
Hi there:
I just had a new Buderus Boiler installed with a 2107 logamatic control as well.
The burner run time meter just shows 0 and does not change. The Manual says that terminal 8 needs 120
volts to make it active. I added a jumper from terminal 8 to the hot wire going to the burner, but no change.
I was wondering if anyone had this problem? Thanks
I will try that. If the timer runs all the time I will know it works since L1 is hot all the time. Thanks :-)
Fuse man try this, I keep notes on these matters0
Putting a jumper between terminal 8 and the Burner hot lead worked. Thank you for the information. :-)
