Sweeping my own boiler chimney
amin1992
Member Posts: 50
Hey there guys. I sweep my own chimney for my wood stove and wanted to look into doing the same for my oil boiler.
The boiler flue runs a few feet where it opens up into a terra cotta chimney - not sure of exact size at this time but it's square, something like 6" x 6".
Anyway, when I do the wood stove, all the soot and such falls into the stove where I can vacuum it all out. However, on the boiler, there is no way to get to the bottom of the chimney. The galvanized flue runs horizontally about 3 feet into the terra cotta, and this is about 4 or 5 feet high.
How would I go about cleaning out all the soot that falls after sweeping? Do I need to? Only idea I have had is getting like 8+ feet of Shop Vac hose and fishing it down into there to suck up what I can, but I'd be going in blind.
Appreciate the help!
Are you saying where the flue pipe enters into the chimney, it drops 4 or 5 feet into a no mans land?
They’re should be a cleanout obviously, otherwise I'd fill that opening with cementThere was an error rendering this rich post.
If you can't reach the base with the hose, you need a soot shovel with a long handle.0
Thanks all. Yup, looks like it goes to no man's land down there. Definitely no clean out anywhere.
I'll try to confirm this week. Thanks0 -
I did that once, will never do that again. as the mess I was let with cost me more in time than it was worth. Have a pro do it and install a bottom clean out if needed.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Reline the chimney and incorporate a cleanout tee or wye. Done. Honestly, cleanouts are for planned failure. The codes require them for masonry chimneys but not listed chimney or vents or liners unless the appliance mfr. specifies one.0
- 120 Geothermal
