Installing radiant under existing Hardwood floors with questionable underlayment
I am concerned about the underlayment in my older hardwood floors and how it will react to radiant heat that I plan to install. The paper has a thin layer of asphalt sandwiched in between. I know this product is still used today under hardwood floors but I am worried that there may be some outgassing of the asphalt layer when the floors are heated. I plan on plates underneath and a water temp of 110 max. I am hoping someone has experience with this and can share their knowledge. Thank you.
  • STEVEusaPA
    edited August 2020
    I used roof underlayment (black paper), under my tubing/wet bed/ceramic tile. Never had any smell or out gassing.
    Rosin paper is used under hardwood. Never seen anything but that, unless it’s something with asbestos in it.
    hot_rod Member Posts: 27,321
    Seems like you need to be above 120 - 130m before asphalt impregnated felt paper starts to off gas.
    I have seen outgassing in high SWT temperature rubber tube staple up where 160F was required to meet loads.
    Outdoor reset keeps temperatures to a minimun and avoids wide swings.
  • kenjohnson
    kenjohnson Member Posts: 103
    I was worried about this also with an installation under hardwood floors in a 1926 house renovation. I've run up to 127 degrees F in a test situation and had no odor whatsoever. I'm not sure what exact material the underlayment is, but it was probably used universally in houses of that era.
