Boiler system fluid
RWALD
Member Posts: 23
Fernox F-1 or pro-tek 922 Can someone please help me out on which one to choose. Thanks
Tell us more about your system....
Boiler? radiation? tubing/ piping in the system?
Age?
Are you having issues?
Both are ok if you need them...
Pure de-ionized water would be the best. But you need the proper filter to fill and purge.
IBC boilers hot water heaters aquatherm and uponor piping. New system0
If it a new system some cleaner in for a week running around to flush out the oils would be good.
Then fill w/ clean DI/ de-mineralized water.
You shouldn't need the inhibitor.
http://axiomind.sasktelwebhosting.com/h2o-demineralizers.php
https://www.caleffi.com/usa/en-us/catalogue/filter-housing-na5731000 -
Thank you!!!0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
